Stroker help
Old Nov 22, 2003 | 04:22 PM
1984camaroz28's Avatar
Stroker help
Is it true any SBC stroker kit as long as its a 2 pc rear main seal crank will work in a LT1 Block
Old Nov 22, 2003 | 05:48 PM
RacinLT1's Avatar
LT1 is a 1 piece rear main seal,any 1 piece seal crank for a SBC will drop right in. you can use the older style 2pc cranks IF you run an adaptor for the rear seal.
Old Nov 22, 2003 | 06:45 PM
ok thanks
Old Nov 23, 2003 | 04:33 PM
Does it have to be internaly balanced or can i use an externaly balanced crank
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
