where to find the comp fuse...
Old Nov 23, 2003 | 03:05 PM
twdz28's Avatar
I have the computer out of my car right now... Where do I find the fuse that is in it...
Thanks in advance,
Old Nov 23, 2003 | 03:30 PM
Don't know of any fuse inside the computer.
Old Nov 23, 2003 | 04:05 PM
twdz28's Avatar
Then how do you reset the computer? Just did heads, cam, rockers, need computer to relearn.
Old Nov 23, 2003 | 08:58 PM
If you have the PCM "out", do you have all the harness plugs disconnected? If so, it has no power, and the volatile memory (long term fuel corrections, learned idle position and stored trouble codes) have been cleared. Nothing else to do.
If the harness connectors are still connected, you need to pull the "PCM BAT" fuse for 30-seconds. Its not in the PCM. That fuse is either in the panel at the end of the dash (93/94) or in the underhood box (95 and newer).
If you did any sort of serious heads/cam, it needs more than to "relearn"... it needs a reprogramming.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
drptop70ss
Mar 26, 2015 01:50 AM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
