Timing Chain
Old Nov 24, 2003 | 02:58 AM
aintno6's Avatar
Timing Chain
Will any chevy small block timing chain work for a lt1? Or will you always have to modify the timing cover and sprokets?
Old Nov 24, 2003 | 03:02 AM
JKDZ28's Avatar
depending on the yr of your car you may have to modify the cover , also you'll need an electic WP
Old Nov 24, 2003 | 03:05 AM
97Camaro007's Avatar
It will not work without modding your waterpump gear and having a electric water pump......
Old Nov 24, 2003 | 03:06 AM
JKDZ28's Avatar
exactly
aintno6's Avatar
ok so is GM the only one that sells a timing chain for the lt1? Or are thier other after market companies, that sell a replacement that requires no modifing?
Old Nov 24, 2003 | 04:19 AM
S.J.S.'s Avatar
Cloyes sells a good double roller one for our cars.
Old Nov 25, 2003 | 01:25 AM
aintno6's Avatar
would i need to change the sprocket if I did that? Or does it come with a new sprocket.
Old Nov 25, 2003 | 01:42 AM
sssalah's Avatar
It comes with its own sprokets.
Lunati has a new timing set for LT1, also GMPP LT4 and LT4 extreme duty are other options.
Old Nov 25, 2003 | 08:02 AM
AFAIK, the Cloyes double roller is a SBC style and will not run the water pump either.
You must get a set that is specifically made for the LT1 to be able to use the stock water pump.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
