Lots of Road Noise....Is there a way to silence?
Old Nov 23, 2003 | 11:08 PM
WhiteBeast's Avatar
Ok, I have a convertible Trans Am. It does have a lot of noise in the trunk area and i was just wondering if there was some sort of a kit that i could install to silence some of the road noise?
I saw a kit on horsepower t.v once that installed under the carpet. Im not sure if it would be worth it but hey.. im just curious.
Old Nov 23, 2003 | 11:10 PM
longwaytofall's Avatar
you can try pulling your carpet and putting down some dynamat or something along those lines. my buddy did it with his bronco and it made it quite a bit nicer. check out car audio companies or ebay.
Old Nov 23, 2003 | 11:11 PM
Red96Lt1's Avatar
Tires are a pretty big factor. I think they don't insulate sports cars as much as other ones to keep weight down. That could be one reason.
Old Nov 24, 2003 | 01:13 PM
plappo's Avatar
I sprayed the entire underbody of my car with an exterior waterproof spray-on sound deadening material. Before I did it, I cleaned off any flaking paint caused by rust, removed some rust and totally degreased and cleaned the underside. I applied about 1.5 gallons total. It took a week and was a messy job, but it totally cut down on road noise and my underbody will probably never rust out. A good thing since I live in highly the corrosive Chicago, IL. I used http://www.partsexpress.com/webpage....ectGroup_ID=19 I used the black stuff in the 1 gal containers for this. About 18 months ago and not a single bit has flaked off. This is my daily driver, so I wanted to cut the road noise as much as possible. I also took off much of the interior body panels and sprayed this stuff into all of the cavities that are exposed to outside noise. I wish I used a SPL meter to determine exactly how much I cut the noise down, but it was significant and if I ever buy another F-body, it'll probablybe one of the first things I do to it.
Old Nov 24, 2003 | 01:15 PM
FacelessZ's Avatar
yea psi in your tires and your steel DS can have bad vibrating problems at higher speeds if you've changed gear ratios...Dynamat should help out a lot, but its a PITA to do yourself...
Feffman
Oct 9, 2015 05:44 AM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
jayblev95
Jan 6, 2015 11:52 AM
