NGK TR6 spark plug gap with ATI procharger
Old Nov 23, 2003 | 11:00 AM
OrionSPL's Avatar
I am in the process of putting my motor back in and bolting on my ATI Pro-Charger D1-SC. Anyone know what gap I should use with the NGK TR6s? I will be running 12lbs of boost on the street with 94 and 14lbs at the track with 110. Other mods listed in profile. Thanks!
Old Nov 23, 2003 | 12:18 PM
OBE1 95Z28's Avatar
I'd suggest you post this in the Forced Induction section. Assuming you have an aftermarket ignition, I'd suggest you gap your plugs at .035". You need a hot spark and smaller gap to prevent the spark from being blown out. I also think you'll want to run a colder plug for 12# of boost; I run 2 heat ranges cooler (Autolite 103s) with 10# of boost.
Old Nov 23, 2003 | 01:04 PM
OrionSPL's Avatar
Yeah, I have an MSD 6AL. I think they said the TR6s would be fine. If I need to go colder then that it should be a problem. Thanks!
racecarz28
Mar 30, 2015 09:55 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Jazsun
Dec 29, 2014 12:14 PM
SC97TA
Sep 15, 2002 01:10 AM
