!cags
Re: !cags
CAGS stands for Computer Aided Gear Selection. At certain situations the car will force you you to shift 1-4. !CAGS disables that feature.
I noticed you have an Auto, the !CAGS is only for M6 cars.
Re: !cags
The only "EGR mod" is deletion. It doesn't gain any performance, because the EGR valve doesn't operate at WOT. The system can actually provide some benefits during low rpm/moderate load operation. The LS1 is different.... the tube in the intake manifold that distributes the recycled exhaust gasses sticks down and blocks air flow from the throttle body. They shorten the tube so it doesn't block the TB. The LT1 intake doesn't look the same.
A helpful hint.... board guidelines suggest a 5 line maximum for a "signature".... yours is a bit over that.
