Do i have too much or too little trans fluid?
Old Jan 12, 2005 | 09:58 PM
pHEnomIC's Avatar
I cleaned my trans out a few months ago. Cleaned out the pan good, emptied the lines that i could get to and even siphoned some out. I couldnt really tell exactly how much i took out. I put in a new filter and added 5-8 quarts dexron 3 mercon(cant remember exactly how many). I am a little worried lately because i am having a sloppy shift from 2-3.
I check the trans level and the level is above hot. It always seems to be above hot no matter what on the dipstick. I attributed that maybe i put in too much so i didnt worry much. I am also thinking that there may be too little fluid and its overheating. How can i tell and should i siphon some out?
Will it hurt anything to have a quart or two extra fluid in there?
Btw, any additives that i should toss in?
Old Jan 12, 2005 | 10:15 PM
LT4orbust's Avatar
Re: Do i have too much or too little trans fluid?
if you overfill it too much, the fluid will touch the rotating parts and air will be mixed with the fluid, i would take some out, 1/2 quart at a time.
as far as additives... i wouldn't use them
warmeck
Aug 24, 2024 08:05 PM
PCLZ28
Dec 24, 2015 05:19 PM
Klypto
Jul 2, 2015 04:49 PM
warmeck
Mar 16, 2015 07:02 AM
jackpawt883
Feb 26, 2015 09:04 PM
