Finally Found the Valve Cover Modification Link
I remember seeing this a while back, but for all my searching on this site, I couldn't find out how the stock valve covers needed to be modified for Pro Magnum RR's.
Here's the link I found on the net:
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Hopfully this thread will pop up when others do a search now.
Dan
Dan
Re: Finally Found the Valve Cover Modification Link
Dan
Dan
-Dustin-
i can set the valve cover down on tp of them with out any problem. how would i know if they were not clearing the cover? would it screw something up as soon as i started up the car?
I've never heard of doing this mod with Crane RR's. It's just a Comp Cams Pro Magnum mod.
Dan
There is no need for the mod if you are using the Crane rockers.I have used both the GMPP SA rockers(made by Crane) and the Crane gold race with out any problems.
Used that technique myself, works like a champ.
Now if someone could invent a temporary finger shrinking procedure, installing RR's and valvesprings would be simple.
