help! Driveshaft ?'s
Old Jan 12, 2005 | 12:33 PM
iCE's Avatar
iCE
I am wanting to give my friend my o.e.m driveshaft off my 94 z28 so that he can put it on his 97 v6. will this work? I want to get a aluminum driveshaft.
Old Jan 12, 2005 | 12:57 PM
Pasky's Avatar
Re: help! Driveshaft ?'s
Just, bolts right up. Still got my V6 steel driveshaft. The T-56, T-5, 700R4, and 4L60E's all have the same driveshaft length.
Old Jan 12, 2005 | 01:01 PM
iCE's Avatar
iCE
and it doesnt matter if the transmission is different? I have a 6speed and his has an auto matic
Old Jan 12, 2005 | 01:52 PM
I am not sure what year they quit using 2 piece drive shafts in the the V6 cars, but even if he has a two piece, your one piece will still replace it ok. He will just have to remove the intermediate bearing.
Old Jan 12, 2005 | 01:55 PM
I thought there was in interference on some V6's with the harmonic damper ring that is mounted at the front of the V8 one-piece driveshaft?
Old Jan 12, 2005 | 01:56 PM
Pasky's Avatar
:blah:
I just explained that.
Old Jan 12, 2005 | 03:41 PM
iCE's Avatar
iCE
you sure did. sorry I am not familiar with transmission stuff at all.
Old Jan 12, 2005 | 04:18 PM
Pasky's Avatar
T-56 = six speed
700r4 = automatic that came in thirdgens (not sure if the fourthgen v6's use this or the 4L60E)
4L60E = automatic from a fourthgen v8 (maybe v6)
T-5 = 5 speed that came in the v6 fourthgens.
Old Jan 12, 2005 | 05:50 PM
961le's Avatar
i know the slip yoke is different. i changed mine from auto to man. the t56 yoke is longer but the shaft is the same.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
