fuel line retainer clip help (broken clip)
The little retainer clip inside of the larger of the two fuel lines broke on me today trying to re-attach to the fuel rail.
Anybody have a part number or any advice on replacement? Or, do I have to buy a whole new fuel line?
The little yellow O-ring was destroyed too. The clip's been giving me problems for a year or more now and I have to massage it every time I reassemble. This time it decided it had enough I guess.
Re: fuel line retainer clip help (broken clip)
Follow up question:
Can I used Earls AN compression fittings on the fuel rail side like in this thread:
http://web.camaross.com/forums/showt...l+line+fitting
and then use some sort of similar adapter on the ends of the hoses? Or, I guess I'd have to then run braided line from the fuel rail back to the hard lines under the car. I'm assuming that would be a major PITA and not cheap either.
I need the simplest and/or least expensive way to remedy the problem.
GM does not sell the clips inside the fuel line connectors, but some people have bought generic replacement connectors at the parts store. I don't have specifics.
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
