Does any one actually have ported Trickflows?
Old Jan 11, 2005 | 04:55 AM
Camaro97Z28's Avatar
I'm just wondering. I've been searching through here trying to find out some info, and couldn't find anything. I'm just curious if anyone has them installed and what kind of numbers they put up. I have a set from Ai coming, full port, milled for stockish compression, and I'm thinking I might be a guinea pig Not that it's a bad thing. It'd actually be kind of cool. Anyways, just one of those "I'm bored so why not ask" kind of questions.
Old Jan 11, 2005 | 04:59 AM
atljar's Avatar
Re: Does any one actually have ported Trickflows?
From what I gather, the heads are pretty much identicle to their standard 23 degree SBC head, simply with revised coolant flow. In other words you could do a google search on ported SBC trick flows and get a pretty good idea IMO.
Old Jan 11, 2005 | 05:37 AM
Sweet, I'll check out the sbc numbers and see what I come up with, but anyone with these heads on our cars?
Old Jan 11, 2005 | 09:41 AM
got_hp?'s Avatar
friend of mine has some trickflows being ported by lloyd.........i believe he got about 300cfm at .600 or .650
Old Jan 11, 2005 | 09:39 PM
Sweet Action, sounds good. I'm waiting to see what mine run in the 1/4, however that will probably have to be after I have the money for a 12 bolt. 12 bolt and some Et streets, wheee!
Old Jan 12, 2005 | 05:56 PM
Denny McLain's Avatar
I'll be picking up a ported pair in the next couple of day ported by Lloyd. We'll see how they flow.
Old Jan 12, 2005 | 09:44 PM
Rock on, please let me know. When are you getting them installed? I want to see what track times I'll run with all the stuff I'm putting in.
Old Jan 13, 2005 | 01:18 AM
SStrokerAce's Avatar
I've seen a few sets. Some by Lloyd other ones done by Larry Meaux (MaxRace Software) You can get them too move some air and they are really nice for stroker LT1's and blown LT1's 290-300cfm is not a issue with them.
Bret
Old Jan 13, 2005 | 04:28 AM
GreenDemon's Avatar
Has anyone done anything with the Edelbrocks yet? It seems like they have a lot of potential, with stock size ports and good exhaust flow out of the box. It would be nice to see what someone like Lloyd could do with them.
Old Jan 13, 2005 | 04:42 AM
I'll have to see how they do when I get it all together. It'll be a few weeks, I'm still stuck in Iraq, waiting for my ride out of here.
Old Jan 13, 2005 | 07:31 AM
Lloyd had some personal matters to take care yesterday and has the heads but didn't have time to flow them. I'm sure he will do that later this morning and as soon as I have the numbers, I'll post them.
Waiting on a cam that Lloyd and Bret put together for me based upon the heads and will probably pick up the heads and cam at the same time. Now if only my custom pistons will make it, we can pull the engine and put everything back together.
After three years of absence from racing I'm comming back this year but will mostly do things using a set of everyday tires such as you would drive your car in the rain with. Seems to be an upcomming thing vs a set of 15" wide slicks.
The "everyday" tires are about as good as Drag Radials if you know how to pick them.
Old Jan 13, 2005 | 09:17 AM
aintno6's Avatar
I have yet to see a non drag radial street tire with soft compound that could compete with a drag radial. But heck man lead the way. It would pretty wicked to see a LT1 car running fast times on 100% street tires.
Mike
Old Jan 13, 2005 | 10:09 AM
Mike
Suppose to be a secret weapon….. We’ve got a race set up in about a month and a half that I’ve been preparing for and the rules are….. LT engine, no power adders and no slicks or drag radials. Even though there will be some cars with power adders.
I’ll post afterwards how these tires work as they are supposed to be……… A secret! But within the rules of this shootout.
Old Jan 13, 2005 | 03:15 PM
I picked them up this afternoon. The heads flowed 246/155 @ .400 and 293/195 @ .600.
The intakes pretty good but the exhaust is a little weaker than I expected in the mid ranges. We’ll see how the car dyno’s as it appears they are very similar to LT4’s comparing same valves sizes.
Old Jan 13, 2005 | 09:17 PM
Sweet. Being stuck in the desert sucks when I have stuff for my car.
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
