Camaro with Z rated tires
Old Jan 12, 2005 | 12:19 PM
camaroguru1's Avatar
Is there any diffenence between a Z28 that came from the factory WITH Z rated tires and one that did not?
Old Jan 12, 2005 | 12:45 PM
camaroz28_97's Avatar
Re: Camaro with Z rated tires
All 93-97 Z28 came with LT-1s that im sure of. However i think that the ones that didn't come with Z rated tires have a spedo that only goes up to 125mph and the might have a different suspension... not sure though
Old Jan 12, 2005 | 03:58 PM
Spinner's Avatar
No Z rated = 115mph speedometer and speed limiter
Old Jan 12, 2005 | 05:43 PM
jpack24's Avatar
If you were wondering rpo code QLC
Old Jan 12, 2005 | 06:50 PM
tfs95z28's Avatar
My car was used and the dealer put new tires on it... too bad they didnt put Z rated tires on, but my car still has the 150 mph speedo... Im pretty sure that the only cars with 115 speedo's are the V-6's
Old Jan 13, 2005 | 05:50 AM
Mtrhds94Z's Avatar
This comes up about every 53 days..
Non Z rated tire Z28's came with a speed limiter AND 110 not 150 speedos[not 115 either.. birds have 115 or 155 speedos]
Z rated tires = no limiter[or set very high like 255] and 150 speedo..
Old Jan 13, 2005 | 08:46 AM
stereomandan's Avatar
Unless I'm reading your post wrong, my car does not follow what you say.
I ordered my car new, with the standard, non Z rated tires.
My speedometer is 150 mph(or 155, can't remember), and I had the speed limiter somewhere around 115, which sucked. The speed limiter has since been removed.
Dan
Old Jan 13, 2005 | 10:56 AM
ShawnMacAnanny's Avatar
Dan
Same here. Speed limiter at 113mph, but 155mph speedometer.
Old Jan 13, 2005 | 12:21 PM
Mtrhds94Z's Avatar
See:
http://web.camaross.com/forums/showt...ght=150+speedo
Especially page 3 'madwolf' posts.. who programs PCM's and should know when speed limiters are present or not..
I am sure not going to debate it.. maybe a few came thru with 150's and limiters.. due to a shortage od 110's on the assembly line etc?...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
globalprojeff
Dec 6, 2014 04:18 PM
