Lost!!!
Old Jan 10, 2005 | 04:41 PM
vonmoldy's Avatar
Lost!!!
A few questions.
What plugs for my car? 1995 camaro z28. I got Autolite AP106 platinum Are these Good?
Tips for changing plugs?
I need a cheap if not free way to scan my car for touble codes and some tuning stuff. Any suggestions???
Old Jan 10, 2005 | 04:56 PM
Kataklysm's Avatar
Re: Lost!!!
Most people run either the factory GM plugs or NGK TR55, I guess the car just seems to respond well to them, nothing wrong with what you have though, just make sure you gap them correctly at .050 There really is no simple way to change the plugs, be prepared for lots of scrapes and cuts, take your time and if you get POed just walk away from it for a while.
Old Jan 11, 2005 | 05:37 PM
vonmoldy's Avatar
Re: Lost!!!
thanks for reply
Old Jan 12, 2005 | 02:48 AM
vonmoldy's Avatar
Re: Lost!!!
Old Jan 12, 2005 | 06:35 AM
teke184's Avatar
Re: Lost!!!
remove the alternator, remove the passenger side motor mount bolt and jack the motor up 2"
i changed all passenger side plugs from the top in 20min after that
driver side the front 3 are accessable from the top and the rear is from the bottom
NGK tr55 work good and are inexpensive
there are several scanners available that are about $100 i think, i've seen some at the local parts store. or guy a used hypertech off ebay or here.
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
