CC 306 QUESTIONS From people who have done them
hi i really want to do this cam but a couple things are holding me back first i really dont know excatly everthing i need to have new like springs i also want to add new rockers while im done there i also am a ***** and dont know how long it will take me to accomplish it and i also want to know if my car is going to be able to idle without my foot on the gas also is it defintly worth it like will i really feel the difference when im done?
Re: CC 306 QUESTIONS From people who have done them
this cam is awesome,great power!comp cams suggests their 987 spring w/associated retainers and keepers,hardened pushrods,new timing chain Lt4 or aftermarket.as for the rockers 1.5 or 1.6 pro-forms,comp magnums,crane are my top choices(not in order)it would be better if you had the heads ported and have 2.00 1.56 valves installed,svo 24lb inj.,larger volume fuel pump(255lph),Lt headers 1-3/4s,3000+stall if auto and a pcm tune,the gains from this set up are awesome it will take you into the mid to lo 12's from stock times add some gear and seat time you may dip into the 11's all these times are ON TIRE
this set up will more than likely not be emission freindly
.it will pass if you use a little less cam,say in the 218-236 @.050 range.
hey man do you recommend those shorties or do you think they are a waste of time i hear alot of people say long tubes or nothing what are your thoughts?
anything is better than stock manifolds. While you will see more power from longtubes over shorties, shorties are usually easier to install and don't require custom exhaust. and generally they are cheaper.
Hurin
Dec 13, 2014 07:38 PM
Z28Wilson
Aug 1, 2002 04:27 PM
