steam pipe???
Old Jan 8, 2005 | 04:46 PM
lethalz's Avatar
Question steam pipe???
I have my TB by-passed, but the steam pipe looks that is useless now, why i have to keep it. Any problem if i remove it?
Old Jan 8, 2005 | 04:49 PM
firetird's Avatar
Re: steam pipe???
if you do a search you will find quite a bit of info on the subject. most say that it is pretty important and to keep it, but there are also several people running without them and have not had any problems.
Old Jan 8, 2005 | 05:02 PM
Re: steam pipe???
The steam pipe is not useless. It helps to remove steam pockets from the heads. It is there because of the reverse cooling system.
Old Jan 9, 2005 | 12:29 AM
Re: steam pipe???
And, to add to what Rob said, doing the TB bypass, if done correctly, does not eliminate the function of the steam tube. The return hose from the rear of the heads should now be connected to the line that used to return the coolant from the TB to the right-hand tank of the radiator.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
