help quick!just cracked wp replacing sensor what to do??
Old Jan 9, 2005 | 02:18 PM
red96z's Avatar
i cracked it tightening the senor to tight now it leaks have to replace tonight.so with that said being that i have a csi can i go with the cheap pump and just put the csi on the new pump.i remember that there was some modifications using the csi like dremel work but i didnt do it so is it hard also is there anything else i should know before i start looks preety easy otherwise.thanks for the help.
Old Jan 9, 2005 | 02:32 PM
MaxLean's Avatar
Re: help quick!just cracked wp replacing sensor what to do??
Are you saying that you cracked the water pump housing where the coolant temp sensor screws into it? If so, that's pretty much the end of that waterpump. As far as the CSI goes, all you need to modify (besides the obvious of removing the old guts and installing the freeze plug) is to grind four reliefs in the housing for clearance for the screw bosses on the CSI. Of course you'll need to use the non cracked housing. By the way, I understand the Meziere pump requires no grinding.
Old Jan 9, 2005 | 02:44 PM
red96z's Avatar
i know i need a new one but like i said before can i get the cheap one being that i have a csi.so when i have them both together its pretty self explanatory on the exchange.how much coolant needs to come out and from were would be the easiest option.also do you know what tools are involved cause im going to have a friend bring them.when u say freeze plug can i use the old one or does it have to be new also.
Just for reference, the sensor is a tapered pipe fitting. The more you screw it in, the more pressure it puts on the hole. The sensor is not made to be screwed all the way in, just until it does not leak. Some thread sealant is also recommended.
Old Jan 9, 2005 | 02:50 PM
red96z's Avatar
shoebox is it a pretty easy exchange or is it going to be a pain just need to know if i can do it before i start.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
