What Spark Plug Wires?
Old Jan 10, 2005 | 07:55 PM
scmudslinger's Avatar
I own a '93 Z28 with OEM, yes I said OEM, spark plugs. The car has 84,000 miles on it and I need to change them, obviously. I'm not looking for something for hard-core racing, and I'm going to install Bosch Platinum +4's, so help me out.
Old Jan 10, 2005 | 08:00 PM
30696bird's Avatar
Re: What Spark Plug Wires?
OEM will work fine. here's a link to read VERY, VERY, VERY good info....... http://web.camaross.com/forums/showt...ight=lt1+myths .
Old Jan 10, 2005 | 09:30 PM
OBE1 95Z28's Avatar
OEM wires and spark plugs are fine for a lightly modified engine. If the price of the OEM wires is high, the Accel 9000 wires are nicely made and are only slightly larger (8mm vs 7.5mm) diameter than the stock wires, therefore they'll fit in the stock looms with only minor persuation.
Old Jan 10, 2005 | 09:34 PM
teke184's Avatar
don't waste the $$$$ on the 4+
get the NGK tr55 plugs for $2 each, taylor spiro-pro wires for $50 and be done with it.
they are more than sufficient for most street engines, are affordable and will fit in stock wire looms
Old Jan 10, 2005 | 09:45 PM
Birdman7389's Avatar
I'm with him, on all points. I personally got the OTVC kit with TR55's from Thunder, and have had no problems.
Old Jan 10, 2005 | 11:27 PM
Deenasty's Avatar
AC Delco plugs here, with Taylor 10.4mm thundervolts
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
