How Strong are LT1 Connecting Rods??
Old Jan 13, 2005 | 03:15 PM
Muskys SS's Avatar
What kind of HP Level can the stock LT1 rods take?
Old Jan 13, 2005 | 03:24 PM
zx1216's Avatar
Re: How Strong are LT1 Connecting Rods??
i'm not exactly sure there is an exact number but there are a lot of guys runing 400+ to the wheels with the gm "pink" rods in the lt1.
Old Jan 13, 2005 | 03:36 PM
ibanez6rg's Avatar
I'd say they're tough enough.
Old Jan 13, 2005 | 03:37 PM
Dave89IROC's Avatar
the stock LT1 PM(powdered metal) rods are as strong, if not slightly stronger then the old "pink" rods
I have a set of PM rods in a 450 FWHP motor and have no worrys at all
Old Jan 13, 2005 | 04:55 PM
zx1216's Avatar
ahh, my bad i thought the pink rods were in the lt1, maybe not tho
Old Jan 13, 2005 | 05:01 PM
According to lore, some had them, some didn't.
Old Jan 13, 2005 | 05:21 PM
The two cases of connecting rod failure that I have seen documented, at least for the LT1 PM rods, occured at approx 600HP. The factory rates them at 450HP, and claimed that was an upgrade from the "pinks". The LT1 engines were switched to the PM's during 1994 (Corvettes) and 1995 (F-bodys), from what I have read.
Old Jan 13, 2005 | 05:53 PM
NOMAD's Avatar
425 hp and 7,000 rpm. Rods even held up to put a hole in the cylinder wall...lol. stupid valve spring broke
-Shannon
Old Jan 13, 2005 | 06:51 PM
96capricemgr's Avatar
The early '70s LT-1 used "pink" rods I think that is the source of confusion. Those were for years the best factory rods, till the LT1(notice no "-") came around with the powdered metal rods. These are capable of handling a lot of power, a couple of 10second b-bodies use them think about the power it takes to get one of those whales into the 10s.
Old Jan 13, 2005 | 08:24 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Mine have held up to >520rwhp ~ 600rwtq w/out issue. Even melted a Forged TRW piston one time ~ had the rods checked, and put them back in my car. Stock crank too.
Old Jan 13, 2005 | 08:55 PM
Muskys SS's Avatar
Nice!! That's what I like to hear.
Old Jan 13, 2005 | 10:11 PM
97WS6SCharged's Avatar
Generally it's the rod bolts that fail, not the rods. Just replace the bolts and have the rods shot peaned and checked and you should be good to go.
Old Jan 13, 2005 | 10:19 PM
TCAL95Z's Avatar
I took apart a 94 LT1 in my engine class and it had GM forged rods in it
Old Jan 13, 2005 | 10:26 PM
GreenDemon's Avatar
So you're saying some ARP hardware should hold up to some heads & cam, plus a little nitrous? Sounds good to me. I always thought the connecting rods were on the weak side on the LT1, I guess I was wrong. So I'm assuming the weak point on the bottom end is the pistons?
Old Jan 13, 2005 | 10:31 PM
For nitrous or a head/cam package the cast pistons are adequate, they become the weak point when you start looking at supercharging or turbocharging. Anyways, a set of ARP bolts will definately help.
