Racetronix Q...
Old Jan 12, 2005 | 06:55 PM
jbsupra89t's Avatar
Racetronix Q...
Hey,
Just finished the beginning of the pump install, I'm letting the glue sit right now overnight I called it quits for tonight. My question is, I gooped the pump with all that silicon grease stuff, and my bucket had them ribs in it. So I busted out the dremel and ground 'em down all the way, but the pump still appeared to sit the same. It slides down, but doesn't really "click" I guess like the instructions say. It aint going anywhere, and with the bucket glued I'm not sure how it could anyway. How will I know when I test it all out if I did it wrong? I'm surprised with how easy the trap door method is...
-J
Old Jan 12, 2005 | 09:08 PM
bdc95ta's Avatar
Re: Racetronix Q...
It's been a while but I just shaved off those ribs enough for it to sit flush.
-b
Old Jan 12, 2005 | 09:30 PM
Spinner's Avatar
Re: Racetronix Q...
Dont worry about it, just throw a pressure gauge on the rail and verify its making proper pressure once it sets.
Old Jan 13, 2005 | 09:51 AM
jbsupra89t's Avatar
Re: Racetronix Q...
Well, finished the install, fired it up, still has trouble starting, but not NEARLY as much. Considering my plugs, wires, and fuel pump were all original 116k mile parts (well maybe not plugs and wires, but they're new anyhow), am I correct in thinking that it just could possibly be that my starting problems lie elsewhere? The fuel pump was my first choice because others seemed to have had this problem. What would you suggest looking at next? Starter?
-J
Old Jan 13, 2005 | 12:07 PM
camarokid24's Avatar
Re: Racetronix Q...
Quick question for ya, did you transfer the lock fitting off the flex tube from the old pump to the flex tube on the new one ? If not then that is you prob.
Old Jan 13, 2005 | 12:28 PM
jbsupra89t's Avatar
Re: Racetronix Q...
Elaborate, I think I understand what you're asking. And the answer is yes, I used the old "push-lock" fitting with the new flex tube. Unless I'm misunderstanding your question...
-J
Old Jan 14, 2005 | 01:43 AM
Re: Racetronix Q...
Yeah, that was what I was asking. I was asking that because that was the mistake I made when installing my racetronix pump. Alot of people have made my mistake causing the same simptoms that you have discribed. You can take your fuel rail up and see if any of your injectors are leaking I have heard that an injector leak causes hard starting. Good luck man
oh yeah also check the filter.
Old Jan 14, 2005 | 09:36 AM
bdc95ta's Avatar
Re: Racetronix Q...
Did you check the fuel pressure and isolate it down to your fuel pump or just replaced it? Hold on...this artical's going to save you a lot of money: http://mainstreamtopics.com/forum/in...p?showtopic=78.
Actually I just check it and it appears there remoduling the site or something so it's temporarly down but try back.
-b
Hey I think I found it try this: http://mainstreamtopics.com/forums/i...p?showtopic=78
Old Jan 24, 2005 | 01:07 AM
96lt1Camaro's Avatar
Re: Racetronix Q...
Where would you get one of these? I threw mine away with the old pump. I tried the dealer but they dont have them. Is there a part number to it?
Quickss96
Jan 29, 2016 05:56 PM
form94
Sep 23, 2015 07:30 AM
Racetronix
Nov 30, 2003 04:11 PM
Racetronix
Oct 5, 2003 01:27 AM
Racetronix
3rd Gen / L98 Engine Tech
Sep 13, 2002 08:29 PM
