Why do my spark plugs keep getting loose?
I am having trouble with my spark plugs, they all seem to come loose and then usually i get a random misfire code. I don't feel as if the threads are stripped because i can get them snug in there. Im usin ngk tr55s and I tighten them pretty snug by hand first and then snug by ratchet wrench.
They usually get loose by them selves and i can wiggle them with my hand. A few times, they've gotten loose to where i can unscrew it with my hand.
Is it possible that my block is just expanding and there is nothing i can do about it from the heat?
I think my problem is that i used anti seize and didnt clean the threads before and i think i used TOOO much anti seize. Is this causing them to become loose? How can i clean the threads out good and should i even bother putting the anti seize in again when i reinstall? Also, i dont have a torque wrench that will fit in the little nooks and crannies so i was wondering how tight i should make them with my wrench? I usually go as tight as i feel comfortable i wont break them.
Re: Why do my spark plugs keep getting loose?
Only snug them, basically once your wratchet stops, put less then a 1/4 turn on it. Theres no need to kill them. Use a q-tip to clean off extra anti seize.
If they wiggle, odds are the plugs (head) is cross-threaded. I dont like the NGK plugs because of their tip design (it seperates from the plug instead of being one piece) and use autolites, but you should not be able to wiggle a plug.
Dave C.
I tried tightening them when warm but i either burn my hands or they feel exactly the same as fully cooled tightness wise. I don't think i stripped or cross threaded anything unless the previous owner did. Do you think if i took every plug out and cleaned the threads out really good and just used whatever anti seize was left over in between the threads would that work out for me?
Just wondering if you have headers? Even sometimes with manifolds the spark plug socket hits either the header or the manifold....and smushes the socket between the header and the plug....It seems as if they are tight, but they arnt. I have seen it happen quite a few times actaully,
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
BAD00T/A
Jul 21, 2002 07:35 PM
