installing a bigger fuel pump??
Old Jan 12, 2005 | 12:22 PM
detroit1994z28's Avatar
I was wondering how easy was it to install a bigger fuel pump. I have a 94 camaro z28. Is it just a plug in and play type of deal or do you have to drop the fuel tank and replace it. I used to own a 88 firebird and the fuel pump would be inside the tank and it was a big job to replace. Is the camaros pump in the same place or can I just plug it in and go - racetronix fuel pump
Old Jan 12, 2005 | 12:27 PM
Sparkz28ss's Avatar
Re: installing a bigger fuel pump??
its a intank pump...you have to drop the tank to replace it....it does not take that long..just make sure you are low on fuel...heh
Old Jan 12, 2005 | 12:29 PM
Okay thats all I wanted to know. Becuase I have a couple other cars here and the fuel pump is not inside the tank. I just really never took the time to crawl underneath my camaro and check - THANKS again - Mike
Old Jan 12, 2005 | 12:31 PM
camaroz28_97's Avatar
i just did the swap. it is plug and play however you have to drop the tank to access the pump or you could use the trap door method
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
