1.7"s vs 1.6"s
Old Jan 9, 2005 | 05:40 AM
Inutero's Avatar
1.7"s vs 1.6"s
Ok, this is a stock internal motor. Was wondering which would be best. Do I need hardened pushrods for 1.6's? would there be much more of a gain with 1.7's?
Old Jan 9, 2005 | 05:51 AM
rskrause's Avatar
Moderator
Re: 1.7"s vs 1.6"s
If you use a self aligning rocker you do not need hardened pusrods. If you switch to a non-self aligning rocker you need guideplates and hardened pushrods. If you have stock heads you will not gain anything significant from 1.7:1 v. 1.6:1 rockers.
Rich
Old Jan 9, 2005 | 05:54 AM
redfirehawk101's Avatar
Re: 1.7"s vs 1.6"s
I agree, 1.6 roller rockers would be the max on stock heads and even for an lt1. ls1's like the 1.7 roller rockers better from what I have heard.
Old Jan 9, 2005 | 06:32 AM
Dave88LX's Avatar
Re: 1.7"s vs 1.6"s
Just wanted to be an *** and throw in there that it's not 1.6" and 1.7" (inches), it's a ratio as in 1.6:1 and 1.7:1.
Hardened pushrods have nothing to do with the pushrod ratio, but as stated, whether you use guideplates or not.
Old Jan 9, 2005 | 09:31 AM
SnakeSkinner28's Avatar
Re: 1.7"s vs 1.6"s
[QUOTE=Dave88LX]Just wanted to be an *** and throw in there that it's not 1.6" and 1.7" (inches), it's a ratio as in 1.6:1 and 1.7:1.
Do you feel smarter now?
Old Jan 9, 2005 | 09:50 AM
unvc92camarors's Avatar
Re: 1.7"s vs 1.6"s
since you have a 95, you already have hardened pushrods from the factory
Old Jan 9, 2005 | 11:14 AM
92LT1RS's Avatar
Re: 1.7"s vs 1.6"s
Great technical post
Anyway, for stock internals, your best bet is to go with 1.6's as your stock springs probably wouldn't be able to handle the extra lift. Later on, if you switch cams, just get a little higher lift cam instead of the 1.7's.
Old Jan 9, 2005 | 11:23 AM
Re: 1.7"s vs 1.6"s
Well i figured it was about as good as his was, and i guess it didnt sink in as you are not following his advice. They are 1:6, not 1.6'. Remember now, its a ratio.
Old Jan 9, 2005 | 11:33 AM
turbo_Z's Avatar
Re: 1.7"s vs 1.6"s
So people say but I wouldnt trust that word of mouth. REAL hardeneed pushrods are only $20.
Old Jan 9, 2005 | 11:55 AM
96SilverRam's Avatar
Re: 1.7"s vs 1.6"s
I picked up a little bit on stock heads going with 1.6 RR's, but I also have all the bolt-ons. I would say do 1.6's if you intend to do all the bolt-on's as a minimum. I think 1.7's might even make a little more HP (just a little). The use of 1.7's on stock heads become prohibitive in most cases.
Old Jan 9, 2005 | 12:55 PM
Heatmaker's Avatar
Advanced Member
Re: 1.7"s vs 1.6"s
Simple...
How big of a cam do you plan on running?
If you don't plan on going over the LT-4 Specs try the 1.7's
If you plan on going bigger... Get the 1.6's
There's allot of comments and reviews on the Scorpions... on this site...
But to be honest with you I'd go with the 1.6's NSA just so I can sleep safe at night...
Old Jan 9, 2005 | 12:57 PM
hsyr's Avatar
Re: 1.7"s vs 1.6"s
Rich
Have you or anyone else proved this yet? I'm not bashing you but alot of people say this but I have yet to see and proof of it.
Old Jan 9, 2005 | 04:10 PM
Re: 1.7"s vs 1.6"s
i guess
it's your money in the end, not mine
i'd rather just use my pushrods that i already have, just my personal preference
Old Jan 9, 2005 | 04:18 PM
stereomandan's Avatar
Re: 1.7"s vs 1.6"s
It's not 1:6. It's a 1.6 ratio, as in 1:1.6. If the cam lobe moves the pushrod a given amount, the valve moves 1.6 times that.
Dan
Old Jan 9, 2005 | 07:01 PM
95z28txn's Avatar
Re: 1.7"s vs 1.6"s
hey sorry to intrude but i have a comp cam with 510 540 lift and 918 springs could i go with 1.7's and not mess anything up. Also what kind of a lift improvement would i see with 1.7's I was tol with 1.6 my lift would be like 560 570 area.
thanks
