need help with driverside header install
Old Jan 8, 2005 | 06:43 PM
jeepz28's Avatar
Unhappy need help with driverside header install
I have jet-hot longtubs. I have searched and done everything they said.
I have jacked the moter up a cuple of inches, got the car about 3' and took off the valvecovers. we have tried from the top and the bottom and still got nothing .
P.S. we have the passenger side on and it just sliped rite in
Old Jan 8, 2005 | 06:47 PM
turbo_Z's Avatar
Re: need help with driverside header install
I have heard of this before with the jethots. I believe they are patterned very closely after the Hooker LTs which happen to have a slip fit 1st primary because the fit is so tight. My only suggestion is to jack the motor up even higher... that is really all you can do unless you drop the k-member some.
Old Jan 8, 2005 | 07:22 PM
Z28barnett's Avatar
Have you removed the steering shaft?
Two bolts one at the rack and one up near the fire wall.
Old Jan 8, 2005 | 09:02 PM
Birdman7389's Avatar
My suggestion is to drop the k-member a little, loosen all 3 of the big bolts, but leave a couple threads in. Get a big prybar and have someone pry it down while you slide the header in from underneath. I had to do that for my Jet-hots and my Pacesetters.
Old Jan 8, 2005 | 09:07 PM
TransAmGT's Avatar
hmmm...i've done two Hooker LT's installs and the drivers side was a peice of cake...went in in 5 minutes...the passenger side was a different story though! Jack just that side of the motor up and lower the k-member is all i can think of! Good luck!
Old Jan 8, 2005 | 10:03 PM
Shue97_Z28's Avatar
I had the same problem, although I still had to jack up the engine to put in the passenger side. Try taking out the two rear spark plugs on the driver side, and youll most likely have to go through the bottom. I have Jet hots and theyre a pain in the *** to get in, but once you get those puppies in there and crank it over, youll know it was worth the sweat and blood. Good luck man, if you have any more questions hit me up, my dads a mechanic and helped me with mine, Im sure I could get you some good tricks.
Old Jan 8, 2005 | 11:42 PM
Boosted_Z28's Avatar
It seems th instructions that Jet Hot includes with their headers are not always universal...I too had to drop the K-member in order to get the driver's side to fit. I actually had to remove all 3 bolts on the drivers side of the k-member and loosen the 3 bolts on the passenger side. I also had to remove the suspension bolts that hold the driver's side spring to the fender well. Then I had to pry down on the K-member with a large pry bar on the driver's side in order to gain enough clearence to allow the header to fit in from the bottom. Definately much more work than what was described in the instructions.
Old Jan 9, 2005 | 02:35 PM
jeepz28's Avatar
thinks for the replys I droped the k-member and they went rite in
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
