highest rpm on stock bottom end.
Old Jan 13, 2005 | 05:25 PM
sw89lt1's Avatar
i was wandering who is turning the most rpms on there stock botttom end and how many miles it has on it. i very rarley spin past 5500 due to blowing 2 alternators at higher rpm.
Old Jan 13, 2005 | 05:32 PM
Valkyn71's Avatar
Re: highest rpm on stock bottom end.
I spin to around 6400 with no problems, ive heard of people going as high as 6800
Old Jan 13, 2005 | 05:38 PM
sw89lt1's Avatar
6800 damn thats a lot. too much for my broke a$$
Old Jan 13, 2005 | 05:40 PM
Firehawk_Dude's Avatar
I would also like to know. Heads and cam, i don't see it safe to spin it past 6200. But can anyone prove me wrong (i hope so ).
Old Jan 13, 2005 | 06:32 PM
sw89lt1's Avatar
Unhappy Re: highest rpm on stock bottom end.
ne1 else
Old Jan 13, 2005 | 06:39 PM
96capricemgr's Avatar
The real limit is the pcm can't control spark past around 7000rpms, the rotating assembly will take that.
Old Jan 13, 2005 | 06:50 PM
NOMAD's Avatar
I've gone until the PCM shut off, almost 7300
-Shannon
Old Jan 13, 2005 | 06:56 PM
But for how long have you guys done this? Its hard to belive that you can spin the stock assembly that high every time you make a pass down the track. I'm not saying you can't do it. I'm saying what is hmmmm "safe" and will get my many passes out of the car. I'm sure i could spin it to 7300, but a few times with that and i'm bound to **** up a bearing or throw a rod. Don't ya think?
Old Jan 13, 2005 | 06:59 PM
sw89lt1's Avatar
thats nuts i can't believe it held up.
Old Jan 13, 2005 | 07:03 PM
sw89lt1's Avatar
no one else with alternator trouble?
Old Jan 13, 2005 | 07:10 PM
SnakeSkinner28's Avatar
Had it at 7000 one night after i got it back from PCMforless, didnt know he removed the rev limiter. Other then that not above 6500, the limit i set with the MSD.
Old Jan 13, 2005 | 07:21 PM
NOMAD's Avatar
Everytime it hit the track for a year. The valve springs comp cams kept sending me would not work at that rpm (even though they said so) and eventually took out a piston by dropping a valve. I may want to add that this was a stock parts bottom end. Studs were used and everything was balanced properly.
-Shannon
Old Jan 13, 2005 | 07:35 PM
The LT1 is a very well put together motor, people do not give it enough credit they are stuck thinking about the crap GM built in the 70s and 80s. There are a COUPLE b-bodies running boost plus spray on stock rods/crank, one with stock pistons too the other with forged, granted I am sure those setups do not run over 6500 but it still makes a point about the unexpected strength of our stock components. The one car dynoed around 630hp/690tq to the wheels with 14psi and a rich 100shot
Old Jan 13, 2005 | 08:13 PM
RedWS6TA's Avatar
spin my heads and cam car to 6800
Old Jan 13, 2005 | 08:54 PM
brain's Avatar
GM847 here on stock heads - I shift at 6500. I MIGHT take it to 6800 once, I need to get my tach calibrated a bit better to see if it makes a difference at the track.
