Need springs to match this cam
Cam 224/236 116LSA XE 3192 3196 lobes this is the cam i will be putting in my FI 355..
Right now i am looking at a set of AFR210 raceready 70%cnc
What spring will work on these heads I will have a 1.6rr on the int/ex..I have been told this cam will peak in the 6200rpm range, I would like to have spring to live at 6500rpm
thx
thx
Re: Need springs to match this cam
thx
thx
http://www.compcams.com/Technical/Cu...ML/340-349.asp
I looked at the Comp beehives 26918..but these spring are only good to .600..my cam is at .624 on the ex with a 1.6rr..
IMO, this really isn't a daily driver type of valvetrain.
Good luck...I think you are going to need it.
95chwagon
Jan 13, 2015 09:19 PM
