No Spark!?!?
Old Jan 10, 2005 | 12:06 PM
TravisA's Avatar
No Spark!?!?
Ok here is the deal. I started my car up about two weeks ago and it ran fine. I come home after if had sat for the 2.5 weeks and it would not fire.
I pulled the plug off of the coil and there is no spark coming out of it? But i have tested pin going into the coil and it has 12V.
Any suggestions? Any thing else i can test?
Travis
Old Jan 10, 2005 | 02:06 PM
Red-LT1's Avatar
Re: No Spark!?!?
Ignition Control Module maybe?
Old Jan 10, 2005 | 05:25 PM
TravisA's Avatar
Re: No Spark!?!?
I hope its that...THe ICM is pretty easy to change.
Can the ICM be tested using a multimeter?
Travis
Old Jan 11, 2005 | 03:53 PM
TravisA's Avatar
Re: No Spark!?!?
Old Jan 12, 2005 | 10:41 PM
TransAmGT's Avatar
Re: No Spark!?!?
ummm i don't think so...i just bought a new one the other day..they are 59.99 from autozone...if that doesn't work...take it back!
Old Jan 13, 2005 | 10:20 AM
Deenasty's Avatar
Re: No Spark!?!?
Shoebox's test here will tell you what is wrong..
http://shbox.com/1/4th_gen_tech2.html#opti_test
If there is no spark comming from the coil, it could be a bad ICM, or PCM, or opti..Usually the ICM or opti would fail before the PCM...Test the "B" connector at the ICM, and if you dont get between 1-4 volts, its most likely the opti, or the opti harness, or the ICM..good luck..
Old Jan 14, 2005 | 10:04 AM
TravisA's Avatar
Re: No Spark!?!?
Thanks...i'll try that.
Travis
Old Jan 15, 2005 | 10:40 AM
TravisA's Avatar
Re: No Spark!?!?
Ok i have now tested on the harness from terminal A to ground and D to ground and have 12v. When i switched the meter over to AC and tested from Terminal B to ground I had pretty much nothing...some mV reading. No where near the 1 to 4V.
I'm now going to test the harness from the opti to the pcm. If that checks out ok i guess that only leaves me with a bad ICM or bad Opti.
Can a advance or auto zone test the ICM?
Travis
Old Jan 16, 2005 | 01:53 AM
TransAmGT's Avatar
Re: No Spark!?!?
i dunno about that....just buy one and if doesn't fix it take it back...lol
that's what i did!!
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
