I need a stock LT1 Dyno graph
Old Jan 14, 2005 | 02:26 AM
mitchntx's Avatar
And when I say stock, I mean off the showroom floor, stock.
If you changed the air filter, I can't use it.
I need to see a real graph.
I am running a '96 Trans AM in a road racing series called Camaro Mustang Challenge. The rules are very strict and one of the limitations I have is 230 rwhp ... no it isn't a typo ... 230 rwhp and is dyno verified.
The motor has to be restricted so that all platforms of Mustang and F-Body are competitive. I know it sucks, but the 4thg en is so far superior in all the other aspects that it shouldn't be a huge deal ... I hope.
The problem is, there aren't that many 4th gens in the series and there is virtually no historical data to confirm the graph that we lay down.
So, I need a dyno graph of someone's car, giving showroom stock information. Any year model is OK.
Old Jan 14, 2005 | 02:32 AM
Bersaglieri's Avatar
Re: I need a stock LT1 Dyno graph
So, whats really done to your bone stock car
BTW: This is both good and bad, but I think it would be kinda hard to find a LT1 with 230rwhp or under, even stock. Seems kinda low I guess.
-Dustin-
Old Jan 14, 2005 | 02:41 AM
mitchntx's Avatar
Like I said, we have to restrict the motor and dyno verify it. and by restrict, a restrictor plate is inserted between the throttle body and intake.
SCCA has been doing it for years in T2
I'm not looking for a graph of an LT1 that only puts out 230rwhp. Don't misread my request. Looking for a bone stock graph so that the curve can be used, not necessarily the numbers
Old Jan 14, 2005 | 07:30 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
This is on a WS6... WS6Keith's car actually. I can't find my stock dynograph.
http://www.ws6.com/mod-2.htm
Old Jan 14, 2005 | 08:04 AM
Compstall's Avatar
I got one that's close, since I moved up to this sky-high altitude, but I would think if you posted your request in places with high altitude it wouldn't be hard to do.
I watched a stock '94 TA here with only a cat-back exhaust put down 194 hp at the wheels.
Old Jan 14, 2005 | 09:51 AM
mitchntx's Avatar
So, did the 96/97 version of the bone stock LT1 put down significantly more power than the 93-95?
Why? What did GM do to cause that?
Old Jan 14, 2005 | 12:50 PM
Kreinmc's Avatar
No, they should be similar. Compstall is refferring to dyno's without SAE correction. Since the car he is refferring to is at high altitude it does not make the power that a sea level car would. That is what the SAE correction is for. No way did that car put down 194 rwhp with SAE correction. A stock lt1 6spd witll be in the 255-265rwhp range. Autos are probably 240-255rwhp.
Old Jan 14, 2005 | 02:09 PM
PANZ28's Avatar
230rwhp???....... That'd be pretty low even for a bone stock LT1 A4.
Old Jan 14, 2005 | 04:10 PM
Compstall's Avatar
I dyno'd 240 actual at the ground here, but 296 corrected, which is right on the money compared to dyno's I've had at near sea-level when I lived in Tacoma, WA.
I lost 54 hp and 64 lbs. of torque at the wheels after I moved here.
Old Jan 14, 2005 | 04:14 PM
Pasky's Avatar
Exhaust I think.
Old Jan 14, 2005 | 04:19 PM
DavesLT1's Avatar
Boy, I'd like to see how mine would run at sea level then. Up here in the Denver area it seems sluggish for a V8.
Old Jan 14, 2005 | 04:39 PM
Compstall's Avatar
What altitude are you at? We're typically between 7,000-8,000 DA here. I lost 19% of my power.
Old Jan 15, 2005 | 09:32 AM
mitchntx's Avatar
It's a restricted limit ... a restrictor plate is installed between the TB and the intake, kind of like how NASCAR uses one between the carb and the intake.
Remember, we are competing aginst Mustangs, so the F-Body has to be slowed WAY down in order for them to be competitive.
D1SC383LT4
Jan 1, 2016 01:56 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Jlo
Feb 3, 2015 09:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
