Throttle body won't close
Old Jan 8, 2005 | 05:11 PM
Jeff95TA's Avatar
I put on an AS&M 54mm TB, and it won't close all the way due to the cable. Should I just adjust the cable to make it longer?
Old Jan 9, 2005 | 12:25 AM
Re: Throttle body won't close
Are you sure its the cable? Did you check the throttle stop screw?
Old Jan 9, 2005 | 07:05 PM
Jeff95TA's Avatar
There was a gap between the throttle body lever and the screw, and the blades were slightly open. I found the reset button on the cable and that took care of it.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
