Beehive 26918 vs. 26915 = no change
Old Jan 9, 2005 | 11:12 PM
truedualws6's Avatar
Short Version:
Swapped the 26915 springs and steel retainers with the 26918 springs and
titanium retainers. The SOTP dyno indicates that the problem is still there
exactly the same. So, whatever it is, it's not the springs. The problem can
be seen in the dyno graph in my sig.
Long Version:
I replaced the Comp 26915 beehive springs with the 26918 springs, and also
upgraded from the steel (795-16) to titanium (794-16) retainers. This was
in an effort to resolve the problem in the dyno graph in my sig. So far, I have
replaced the opti, ICM, coil and spark plugs in the past month. The A/F ratio
is solid, and the tuner removed most of the timing for one pull and no change,
so I would rule out fuel and timing. Not that I belive anything at this point. I
have swapped PCMs too.
I am now going back to square one and checking everything again. So far, I
have run the Comp R lifters at 1/8 turn and figured it's time to readjust them
to near zero lash. I reset them to an estimated 1/32 turn today, but can't drive
the car because of the rain. I'll put up the results as soon as So Cal dries up
a bit and I can go for a test drive.
Old Jan 9, 2005 | 11:45 PM
Spinner's Avatar
Re: Beehive 26918 vs. 26915 = no change
Replaced the coil wire? Definetly looks ignition related due to the up and down nature of the spikes. Something mechanical you would think would just be down, and you didnt list replacing the coil wire.
Old Jan 10, 2005 | 12:30 AM
Evil Eric's Avatar
what type of plug wire are you running? some of the major brands have off the bat trouble with bad boots arcing to the block. plug change? gap? i agree with spinner it seems ignition related to me. do you have any fuel system mods ?
Old Jan 10, 2005 | 09:04 AM
SS MPSTR's Avatar
Mike,
Did you inquire with Jeff about this yet?
Old Jan 10, 2005 | 09:12 AM
rocmemphis's Avatar
Check for arcing. Arcing will cause all sorts of weird problems.
Old Jan 10, 2005 | 09:45 AM
Yes, it's a new GM coil wire.
Originally Posted by Evil Eric
what type of plug wire are you running? plug change? gap? i agree with spinner it seems ignition related to me. do you have any fuel system mods ?
New Accel Extreme 9000 wires, new TR5s gapped at .043", no fuel mods other
than AFPR.
Originally Posted by SS MPSTR
Mike,
Yes, have sent a couple of emails. He is at a loss so I'm checking out everything
again. I could really use some data. I need to find someone locally that can
scan this thing and review the data log.
Have not checked for arching. Once it stops raining in So Cal I'll check it out.
Old Jan 10, 2005 | 10:01 AM
stereomandan's Avatar
Just curious why the gap is 0.043" in stead of the stock 0.050"?
I know you are making significantly more HP than stock, but I'm not sure it's enough to justify that close of a gap. I doubt it's causing your problem though.
Hopefully the lash on the lifters is the culprit.
BTW, I think arcing would show up in low RPM's as well as high RPM's. I doubt that's the problem, but worth a look.
Dan
Old Jan 10, 2005 | 10:44 AM
Originally Posted by stereomandan
Just curious why the gap is 0.043" in stead of the stock 0.050"? Dan
I had a couple of recommendations to go to .035" on the gap, and the tuner
suggested .045" max, so I went with .043". I agree with you regarding the
arching and am keeping my fingers crossed that the lash is the culprit.
Old Jan 10, 2005 | 12:41 PM
Interesting. Did they give you any reason for such a narrow gap? I thought our ignitions were pretty good and could handle the 0.050" gap up to the RPM's that we see. I'm not an expert on spark plug gap though, but it seems that I see 0.050" recommended unless people are making SERIOUS horsepower or nitrous.
Granted, I'm making 30 rwhp less than you, but my NGK's are gapped to 0.050" and my engine runs smooth all the way to 6000 RPM. My dyno plot is in my sig. I'm not sure if a narrow gap would cause your issue though.
Dan
Old Jan 10, 2005 | 01:30 PM
Spinner's Avatar
Dan
The closer the gap, the smoother your ignition is going to run. Just less area for the spark to jump. I gap my plugs at .032
Old Jan 10, 2005 | 01:47 PM
ejfagala's Avatar
Did this coure after a cam swap? I saw a very similar graph when someone installed a LT4 HC one tooth off. THe car ran, made 300 RWHP and idled but was severly down on power. Probably has nothing to do with it just throwing it out there just in case.
Old Jan 10, 2005 | 03:26 PM
Originally Posted by ejfagala
Did this occur after a cam swap?
Yes, but I doubt I'm off a tooth on the cam. Dots were lined up just like
the service manual said. I was even trying to verify the install (degreeing)
but gave up once I realized my accuracy was +-3*.
Old Jan 10, 2005 | 03:48 PM
Shon Herron's Avatar
is there any way the valves are hitting the pistons? dont look like a huge cam or that the heads are milled or that you have thinner gaskets but thought I would throw that out there....
Drtryder
Apr 22, 2015 04:17 PM
R@mpage
Apr 20, 2015 10:02 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
