Camaro is dead again
Old Jan 9, 2005 | 04:23 PM
camaroz28_97's Avatar
Angry Camaro is dead again
It’s been a week since my I installed the racetonix kit with the power cable that runs to the battery and now my car doesn’t start. At first it would start and run for a second and then die. Now it just will not start at all. Any suggestions??? I really hope I don’t have to take the pump back out again.
Old Jan 9, 2005 | 04:50 PM
tanker's Avatar
Re: Camaro is dead again
get a fuel pressure tester from autozone or any other car shop and test your fuel pressure, its a 5 minute job. It your car starts right away without having to wait, it may not be your fuel pressure problem. Opti, ignition .... Any codes?
Old Jan 9, 2005 | 04:53 PM
Formula_one's Avatar
Did you connect it properly?
If so, check the fuse that's on that wire you ran to the alternator. Mine was just a few inches from that connection.
Old Jan 9, 2005 | 04:56 PM
car has ran great for a week since i put the new pump in and now nothing
Old Jan 9, 2005 | 04:58 PM
Check the fuse....
Old Jan 9, 2005 | 05:23 PM
well took out the fuse and droped it so i couldn't see if it blown when i went to put a new fuse in it sparked and i droped that one . Is it supose to spark like that?? probably should have disconnected the bat got another fuse and got this one in and the car started right up. Why would the fuse blow already?? its only been in there a week??
Old Jan 9, 2005 | 05:55 PM
neil350's Avatar
96speed has a similar problem with his blowing the fuse.
Old Jan 9, 2005 | 07:20 PM
Not sure, it happened to me once or twice. Just carry a couple fuses with you in the car. That way you're prepared next time, if it happens again. I shouldn't happen too often, if it's a regular occurance I would call the place you bought it from.
Old Jan 11, 2005 | 12:17 AM
well i put a new fuse in again and tonight i went to start the car heard a shocking noise and everything shut down. the fuse blew again and i think i know whats causing it. it looks like the wireing harnes is hitting the manifold i will take it out tommarow and see for sure. now i need a new harness . guss i will be emailing Racetronix tommarow. hope they dont kill me on the price on replaceing the harness.
Anyone have any sugestions on where to run the harness do that it doesn't hit???
Old Jan 11, 2005 | 09:54 AM
When I put mine in I used zip ties to make sure that it was secure. I think I ran mine next to the fuel lines, then ran it across the cross member, then zip tied it to the tranny once or twice and then up behind the motor and next to the rest of the wiring over the top of the motor.
Just take your time and do what you want, but just be careful so that you dont burn it again.
You might be able to repair the harness you have, but I can't see it.
Old Jan 11, 2005 | 03:44 PM
i took the wire out and it just burned through the shieling the wire itself looks ok. Im going to just tape it up wiht black electrical tape. Anyone think this will be a problem???
liamcg97
Nov 25, 2019 05:55 PM
CARiD
Jan 14, 2015 04:00 AM
ro2207
Dec 4, 2014 06:18 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
