harmonic balancer with underdrive pulley removal
Old Jan 10, 2005 | 12:14 PM
95z28txn's Avatar
guys im putting a cam in and i can't get the harmonic balancer to come off it has an underdrive pulley behind it, and they are stuck together chiltons says it should just pull off after the bolts are out but it won't what should i do?
Old Jan 10, 2005 | 01:40 PM
Re: harmonic balancer with underdrive pulley removal
Did you try a generous application of something like PB Blaster, at least 24 hours before you tried to remove the damper? Did you try some gentle tapping with a hammer? Does the U/D pulley behind the damper prevent you from getting a 3-jaw puller in the inside diameter of the damper?
Old Jan 10, 2005 | 06:19 PM
95z28txn's Avatar
i sprayed some brake cleaner on it today and yes the diameter of the od pulley does not allow the puller to fit. any other suggestions thanks.
Old Jan 10, 2005 | 06:27 PM
Pasky's Avatar
Pound it with a rubber mallet, I never bother with a puller .
Old Jan 10, 2005 | 06:49 PM
95z28txn's Avatar
sounds like my kind of plan thanks
Old Jan 11, 2005 | 12:34 AM
Brake cleaner is not a rust penetrant. Use the correct material..... might work better.
Are you saying you can't get the puller over the spokes of the pulley, like this (not over the outside of the damper, where the pulley would interfere with it):
http://shbox.com/1/pull_pulley.jpg
Old Jan 11, 2005 | 12:54 AM
95z28txn's Avatar
Brake cleaner will penitrate rust but lets not get into that. As i said before i have tried to use pullers and they are no good. In the area where the clamp atatches to the pulley in the pic is flush with the underdrive pulley. I have also tried using standard pullers. Any other suggestions? I need to get this piece off.
eanhl2004
Apr 4, 2015 12:01 PM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
