SES Light Flashing Intermitantly...
Old Jan 9, 2005 | 04:44 AM
Ryan's LT1's Avatar
If I remember correctly, this means Random Cylinder Misfire, correct?
I replaced my Opti probably due to rain last year, and if I'm right, looks like I'm doing it agiain. This sucks. Great way to start off the year. No E-cutout for me. I tested it out when it was warmed up, tried to keep it at 2000 RPM's and it would jump around 1800-2400, also my Hi-Fans kept coming on when they weren't supposed to. I could actually hear it misfire, too.
I'll go ahead and get it scanned, but I'm pretty positive thats what it is. What are my chances of it drying off in the next couple days? It won't be driven again until monday. Also, who do I contact to get Opti's for cheap around here?
Thanks guys...
Ryan
Old Jan 9, 2005 | 08:55 AM
Hawk's Avatar
Re: SES Light Flashing Intermitantly...
jason cromer, or you can order them off gmpartsdirect.com, they are alot cheaper then the dealer to.
Brian
Old Jan 10, 2005 | 12:50 AM
Ryan's LT1's Avatar
Thanks.
Old Jan 10, 2005 | 02:05 PM
Ryan's LT1's Avatar
Well I started it up and it immediately started to flash again, with my hi-fans comeing on and EGR going off everytime it Flashed on. I'm pretty sure it's the Opti, but it drives fine so far when both cold and warm. I can tell that it wants to rev th engine sometimes but I don't think it is completely gone yet. Anyways...
Is there something else I should look for that gives similar symptoms? It will be getting scanned tomorrow.
Old Jan 10, 2005 | 02:15 PM
Your signature indicates you have a 1994. They do NOT have misfire detection. I'm not aware of any problem in OBD-I that causes the SES light to flash. Almost sounds like you've got an intermittent connection on one of the sensors, or the IC Module.
Old Jan 10, 2005 | 04:39 PM
Dave89IROC's Avatar
yeah, flashing on an OBD2 car means the PCM sees a possible catalyst damaging condition(usually misfire)
Old Jan 10, 2005 | 09:46 PM
Ryan's LT1's Avatar
Hmmmm... All the more reason to get this scanned tomorrow. I'll keep you guys updated.
By the way, on the 4 mile (about 15 minute) round-trip from work to the gas station to home, the light stopped flashing on the way home. Definately going to get it scanned tomorrow to see if it has stored any codes, and I'll let you guys know which one's (if any) it finds.
Heathen1
Jan 2, 2016 04:27 PM
Gtpguy
Jan 26, 2015 04:50 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
