Wild cam need HELP
Wild cam need HELP
Cam 224/236 116LSA XE 3192 3196 lobes this is the cam i will be putting in my FI 355..
Right now i am looking at a set of AFR210 raceready 70%cnc
What spring will work on these heads I will have a 1.6rr on the int/ex..I have been told this cam will peak in the 6200rpm range, I would like to have spring to live at 6500rpm
http://www.compcams.com/Technical/C...TML/340-349.asp
I looked at the Comp beehives 26918..but these spring are only good to .600..my cam is at .624 on the ex with a 1.6rr..
My Valve train right now is
comp R lifters
1peace CM push rods
guid plates
1.6rr pro mag
what do people think of these springs
#K-800 - 1.460 DIAMETER DOUBLE SILICONE SPRING GOOD FOR CAMSHAFTS WITH UP TO .700 LIFT. 155#@1.850 - 450#@1.150 - COIL BIND @1.085
Can the comp R lifter work with that much closed, as they will lose some with heat
comp R lifters
1peace CM push rods
guid plates
1.6rr pro mag
