RPM surge + check engine light
Past few days when i am stopped at lights the car will surge rpms will go up and the car will lurch forward if i dont watch how hard i am on the brakes. Finally last night i started it up and it wouldnt run rught, Check Engine light came on and sounded like it was out of gas, the rpm's fluctuated and would not run on all 8 cylinders. I shut it off, and restarted it. after doing this three times the car fired right up fine, no check engine light, and ran perfectly. It still surges at lights once in a while, so i know it will happen again. Ideas? Thanks!
Re: RPM surge + check engine light
Get it scanned. Once the SES light comes on, the cause is stored in the PCM. It will stay there for a while, clearing itself only after a pre-deteremined number of "drive cycle" without the problem recurring.
OK i will do asap. The car has been back firing lately only once in a while when i stomp on it. It seems like its backfiring through the intake too.
OK i will disconnect it, and plug the vacuum line and see if that fixes this problem. I am hoping that this will fix all my problems, (power loss, gas mileage decrease, stuttering, backfiring) i have pressed on the diaphragm of the egr before and it didnt move, i thought that they were supposed to....is this true?
Jon
Jon
IAC .... It never happened to me but I heard it gets sticky. the PCM tries to compensate with more action till it breaks loose and overshoots.... then the PCM Backs it out but ends up at the sticky point again.. Result is a Car that almost lurches up onto the passing traffic on a stop light. I call it Possesed car...makes you look really stupid if you have a girl in the passenger side.
The IAC Remove it and Clean it. Now about the Backfiring... I will defenetely think of the EGR. I can push mine by hand. Yours sounds like its stuck closed or open or almost open.
(almost open
Marvin
(almost open
)Marvin
ok, how can i clean the iac? What should i use? I am almost 100 % sure the EGR is bad, tonight it stalled while i was driving down the road out of no where. It was very embarassing because my girlfriend was making fun of my car having problems lately, and i defended the car by saying it was fine. not 5 mins later it just stalled. Its ok though, I got on it real good and wasted a Turbo CRX really bad and then that shut her up
Have you pulled codes yet? Before you start trying to guess what is wrong see what the computer tells you. If the F-body is the same as the Corvette on the 94/95 you can short pin 12 to pin 4 on the DLC and it will flash the codes.
Jan 5, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
