Would oil pres. going down under acceleration mean cavitaion or drain back issues.
Old Jan 11, 2005 | 02:29 PM
BlackLT1_TX's Avatar
I dont think it has to do with the G's the car is pulling, it seems different.
It will go from 70+psi to 35-45 psi then back up and down under hard acceleration.
Anyone know if a aftermarket pan/pump would solve this, or does it sound like the pickup is too close to the bottom of the pan?
Old Jan 11, 2005 | 04:39 PM
NOMAD's Avatar
Re: Would oil pres. going down under acceleration mean cavitaion or drain back issues.
Sounds like either the pick up is too close or you've spun a bearing.
-Shannon
Old Jan 11, 2005 | 06:12 PM
Lonnie Pavtis's Avatar
The stock pan has poor baffling & will uncover the pickup under acceleration.
The faster the car, the worse the problem is.
High volume pumps suck more oil from the pan & amplify the problem.
Old Jan 11, 2005 | 07:12 PM
chy20k1's Avatar
so an aftermarket pan would solve the problem?
Old Jan 11, 2005 | 09:10 PM
It might in some situations, but there are plenty of people out there with stock pans with no problems.
Old Jan 11, 2005 | 11:30 PM
-Shannon
Motor is brand new. The car always has great oil pressure, lowest I have ever seen is 20+ psi and thats after 40 miles at around 3krpms. There isnt a way to push the pickup up through the drain hole is there?
So you still think it is the bearing? When I have spun bearings on other motors the oil pres. sucks.
Is there anyway to test to see if the pickup is to low, like running a 1/2 quart low or something?
Old Jan 12, 2005 | 12:40 AM
atljar's Avatar
My cam only car would do that VERY badly. 50ish until 4k and then it would start sucking backwards.
The new motor got a miloden 7qt pan with baffles and a 1qt filter and it holds pressure all the way through the rpms
Old Jan 12, 2005 | 09:57 AM
Loadre's Avatar
My new motor never gets above 45-50 at WOT. Melling Pump (not high volume), stock pan, etc.
Old Jan 12, 2005 | 03:58 PM
ttt
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
jayblev95
Dec 1, 2014 06:55 AM
Snoman73
Nov 17, 2014 07:22 PM
