"Oil Pressure Low at Idle"
Old Jan 13, 2005 | 01:23 AM
ptown's Avatar
Exclamation "Oil Pressure Low at Idle"
After my engine warms up and you come to a stop and idle the oil pressure goes down and the check quages light comes on.Ive replace the sending unit does anyone know whats going on with this....
Old Jan 13, 2005 | 01:25 AM
Spinner's Avatar
Re: "Oil Pressure Low at Idle"
Stop driving your car, drop your oil pan, and put your oil pump pickup back in your oil pump, and SECURE it (bolt it, weld it, braze it) somehow.
Failure to do so will result in everyone's favorite noise, a spun bearing knock. Ask me how I know this
Old Jan 13, 2005 | 01:31 AM
ptown's Avatar
Thanks for the info those jack A$$s at the dealership said drive your car around and see what happens. Ill drop the pan tomorrow and take a look. Thanks
Old Jan 13, 2005 | 03:07 AM
Est96Z28's Avatar
Have you swapped the cam ? It could be the cam bearing or weared main/rod bearings. I had the same problem 5 k. miles after hotcam install and it was due to cam bearings which probably were hurt during the cam swap. Hopefully it's just pickup, although I guess then you should have problems also during the high revs ?
Old Jan 13, 2005 | 03:16 AM
BlackLT1_TX's Avatar
I also think that Spinner might be a little quick to say pickup.
I would lean more towards a bearing problem, probably rod or cam bearings. I know my heads/cam/blower 5.0 had the oil presure drop at idle when warm and thats what it was.
-James
Old Jan 13, 2005 | 06:17 AM
96WhiteZ28's Avatar
I totally agree with Spinner..... I had the same problem and changed the whole pump before it did any damage.... search the boards... it's happened to people before and if it's not fixed you'll regret it...
Old Jan 13, 2005 | 06:20 AM
96WhiteZ28's Avatar
-James
By drop do you mean all the way to 0 where your check gauges light comes on? With the pickup falling off... it happens when you brake especially if you brake hard... Pepboys wanted $1100 for the work and then a local speed shop did it for $400 which included new melling pump and oil and all that so I had them do it. $400 to me was better then a rebuild..
Old Jan 13, 2005 | 07:15 AM
Oil pressure will be lower at idle. You need to specify what the pressure is.
Old Jan 13, 2005 | 10:18 AM
mebanditws6's Avatar
Aye, the check guage light could just be going bad. If you're getting 15psi, that's still fine, but lower than normal. What's your pressure when driving? Normally LT1's run around 20ish warm idle, 40ish cruise, 45-50+ WOT.
Jason
Old Jan 13, 2005 | 01:00 PM
trynpas's Avatar
Not to point out the obvious, but did you check your oil levels? Low oil can register low pressure...
Old Jan 13, 2005 | 09:49 PM
ptown's Avatar
The oil pressure doesnt go all the way to zero but just above it. It dips way down into the orange on the oil pressure guage, And yes I did check the oil for you wise guys out there.
Old Jan 13, 2005 | 09:57 PM
CamaroSS30thAnn's Avatar
isnt it like 6-10 psi for every 1k rpm?
Old Jan 13, 2005 | 11:05 PM
zx1216's Avatar
Thats true but that is after the base 20 idle psi.
Old Jan 13, 2005 | 11:27 PM
The factory manual says 6 psi is the minimum oil pressure at idle. Of course, it's better to have it higher than that.
Old Jan 13, 2005 | 11:46 PM
zx1216's Avatar
Wow, 6psi, i would shut my car down if it was that low, i think i read in the lingenfelter SB book that idle should be around 20 and beyond that the oil pressure should be 10 psi for every 1000 rpm's. So 60 psi at 6k rpm's. Thats on the safe side probably but he knew what he was talking about.
