Fuel injector size selection
Old Jan 9, 2005 | 08:36 PM
NVRLATE's Avatar
I'm not sure about the extent of my future mods so I was wondering can you add larger fuel injectors than what you actually need? I will problably go with the LE2 head/cam package this spring and I will more than likely add NOS sometime down the road. I don't want to buy injectors twice.
Old Jan 9, 2005 | 08:44 PM
OBE1 95Z28's Avatar
Re: Fuel injector size selection
42# injectors are very tunable, according to Jeff Creech of Carolina Auto Masters, and are good for 600 rwhp. I would recommend going this route. You will need to upgrade your fuel pump to get to this level though.
Old Jan 9, 2005 | 10:14 PM
DavesLT1's Avatar
I believe the equation (and I might be wrong) to find the injector size needed for your desired HP is:
take HP X and multiply by .625, then divide by number of injectors (in our case 8).
To find how much HP a set of injectors at a flow rate will peak at reverse it. Take flow rate X, multiply by number of injectors and then divide by .625.
Old Jan 9, 2005 | 10:24 PM
fstenuf's Avatar
i'm gonna be runnin FMS 42lb injectors with my walbro 255 intake pump. is that pump too small? or will i be fine for a while? thanks. sorry for messin up the thread
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
