last header bolt on passenger side
Old Jan 9, 2005 | 12:41 AM
red 95 z28 lt1's Avatar
im having a hard time getting the last bolt in all the way on my jet hot lt's on the passenger side. i got it started. i tried for an hour, has any one else had this problem. also what have you tried to get it in all the way.
Old Jan 9, 2005 | 12:57 AM
JBirdSS's Avatar
Re: last header bolt on passenger side
I fought that battle also. I found an END WRENCH about 5-6 inches long that had the opening 90 degrees to the handle. I'm guessing the max torque I was able to get on the header bold was 30-35 lbs but I was able to get the bold installed using this wrench. I tried numerous other combinations including a 1/4 inch ratchet and several flex drive set-ups. The end wrench did the job.
Old Jan 9, 2005 | 03:21 AM
Got-LT1's Avatar
With my MAC mid-lenghts I was able to get it with a normal box wrench (though it took forever!). A little trick I use now is that I gut the 7/16 wrench in half so that it is much shorter and i can get a longer swing with it. hope that helps.
Old Jan 9, 2005 | 04:20 AM
95RagtopTA's Avatar
That bolt in a major PITA! I also tried many combinations (from top vs. bottom, sockets vs. wrenches), and even with my stage 8s I still had problems. As mentioned above, best solution is to go get a cheap open end wrench and cut it in half. Then crawl up on your intake, reach back there and use your thumb to push down on it (really sucks when it slips off). Good Luck!
Old Jan 9, 2005 | 04:45 AM
Got-LT1's Avatar
After that episode, I went out a bought mechanx gloves to protect my hands in case I had to do it again....
Old Jan 9, 2005 | 05:21 AM
redfirehawk101's Avatar
I had some trouble installing my headers as well, it can be troublesome. It takes lots of time and commitment. Also lots of patience. Ebay sells a socket for removing and adding sparkplugs. Good Luck!
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
blue89iroc
Jul 26, 2002 04:56 PM
