Stock Chain
Old Jan 10, 2005 | 05:12 PM
94GreenZ28's Avatar
Stock Chain
Here's my problem. Will a stock chain be strong enough for a gm847? My non-veneted opti has about 10k miles on it and I don't want to spend the money to convert. I do have an electric water pump so maybe that will take a little stress off of the chain. I also heard that a timing crank gear and chain from a late 80's 305 or 350 is the same as a 94 chain and crank gear, is this true? Because the set for the late 80's is $21 at autozone and I could just buy a new cam gear and save about $30.
Old Jan 10, 2005 | 05:32 PM
ibanez6rg's Avatar
Re: Stock Chain
The GM847 is a high-reving cam. The stock chain isn't meant for that.
Old Jan 10, 2005 | 05:58 PM
sleepy_z28's Avatar
Re: Stock Chain
I have the Lunati timing set with mine. I honestly don't think that it's any better than a stocker. I just plan on changing mine out every 10K or so.
Old Jan 10, 2005 | 06:09 PM
FastZinTennessee's Avatar
Re: Stock Chain
To the original poster- Don't half *** your car. You need a tougher timing chain. I was running a HOTcam with an electric waterpump on a new stock chain and it stretched it out noticeably. The extra revs and extra force it will take to spin that 847 cam could end you up in a mess if you use a stock chain.
Old Jan 10, 2005 | 06:28 PM
Pasky's Avatar
Re: Stock Chain
Doubler roller. Can't go wrong. Don't waste your money on the LT4 ED set. Just go electric waterpump and double roller.
canbaufo
May 25, 2015 12:01 PM
nikolt1
Feb 27, 2015 09:10 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
