z28 will start then stop
Old Jan 9, 2005 | 08:11 PM
BigTedz28's Avatar
I have a 95 z28 camaro with 160k miles on it....i was in traffic yesterday nite and my car decided to shut off on me...soo i went to fire it up, and it starts for a split second, rumbles, then shuts off??? is this something to do with ignition........any ideas......im in great need.....like i said,
Car starts for a second, rumbles then shuts off...like as if something surges it.....??? thanx for any ideas
Old Jan 9, 2005 | 08:13 PM
Hawk's Avatar
Re: z28 will start then stop
any codes??
Old Jan 9, 2005 | 08:21 PM
BigTedz28's Avatar
nope
just the fact that everytime i try and start it, it turns on then turns off...like something is grounding it out something............
Old Jan 9, 2005 | 08:23 PM
OBE1 95Z28's Avatar
Provide more details; was it running fine up until now and all of a sudden starting doing this? Have you changed anything lately (pulled the intake off). Has the car been maintained;tune-up in the last 30K miles or so? All of this would help us help you. Try unplugging the MAF sensor and see if it will start.
Old Jan 9, 2005 | 08:25 PM
mmmchickenboy's Avatar
I had a similar problem with another vehicle and it turned out to be the ignition switch. Do your gauges light up when you turn the key to the ON position? The electrical portion of the ignition switch might be worn out so that when the key is in the ON position your ignition is not getting the power it needs, but when the key is in the START position the contacts are still good and the ignition works for a second until the key is turned back.
Old Jan 9, 2005 | 09:05 PM
BigTedz28's Avatar
Exactly like you said, once i turned the key to the on position usually all my lights would come up and make this lil noise then the ses light would light up and then bam i would start my car........but now its like i have to turn it a lil bit further then normal "on" for all my lights to pop up on the dashboard......soo how do i fix this ignition switch and where is it located??? thanx a bunch
Old Jan 9, 2005 | 09:35 PM
Good luck on the Chevy ignition switch, I have no clue how it goes together.
You should try to make sure this is the problem before ripping the steering column apart. Turn your ignition to the ON position where your gauges light up, then somehow short circuit the starter solenoid to get the motor to turn over while the ignition is on.
Old Jan 9, 2005 | 10:26 PM
CamaroSS30thAnn's Avatar
http://shbox.com/1/4th_gen_tech1.html
look for ignition switch he has a nice walk through
Noenav
Mar 1, 2019 07:38 AM
HCz28
Jan 11, 2015 11:21 AM
cristian1311
Nov 23, 2014 02:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
