View Full Version : LT1 Based Engine Tech
- Help - engine runs bad when warm
- power steering noise
- power steering
- I need help for my 96 z28 please
- LT1 rebuild??!!!
- How to Change spark plug wires
- Ebay Opti = P0336 CPS out of range??
- hooker short tube help?
- oil pressure and oil pump advice
- Lt1 into Ls1 hole
- Opti Seal
- LT1 Engine lifting plate
- GEN I vs GEN II .. What's the difference? .. Block only.
- tunning needed in northern, ca 94z28 lt1
- Antifreeze leak
- LT1 reliability
- MSD Wire Help?
- Bad WOT Misfire
- Need Help Quick!
- Need Some Help!
- 93 LT1 Fuel Rail Question.
- 1994 camaro z28 A4 doesnt pass smog. need help
- lt4 hotcam .. or comp cam xfi 280 kit.. or.. any preference
- fuel pressure question
- 1994 z28 starting problem
- Stupid question
- 1996 LT1Won't Start
- Advice needed on engine swap 94 z28 swaping 96 engine
- Starter keeps breaking! help!
- shaving lt1 heads
- Need part number for large check opti check valve
- EGR delete, can i cap the vacuum line on the side of the intake and remove the soleno
- stripped transmission bolt
- what counts is the iac supposed to start and idle at?
- All of you engine builders out there.....
- t56 clicking noise
- China wall clearance
- tighten belt tensioner
- Dies after running short period of time, then no fire
- removing 4l60e
- rough idle video
- Factory spec for oil pressure
- Rich gas smell?
- LT1 Rotating Assembly Question
- LT1 build up input needed on injectors.
- 96 LT1 runs for a minute then dies
- rough idle
- car wont start
- Any experience with LE 21* Trickflows?
- code 53 and 93?
- fuel lines under the car question
- 1996 LT1 felt like ran outta gas now no start
- codes 27 and 48
- can vats cause a missfire?
- Check Engine Soon
- Coolant going into the oil pan
- LT1 wont start...
- Optispark? Ugh, I hate typing that...
- Long 2,000 RPM idle on startup/warmup
- car wont crank when no security light
- 12 codes come up. Bad ecu?
- Long Starts (fuel pump, opinions?)
- Head Bolt question...
- Steering wheel column adjustment
- Comp Cam push rod length checker
- A big thanks!!
- looking at buying a new LT1 longblock, suggestions?
- Overheating frenzy
- what Opitspark do you guys rocommend
- Knock sensor in 95 z28 won't budge!
- Very low idle and stalls ??
- Computer chip vs. programmer
- oil filter
- Head Gaskets + Heads
- 94 z28 wiring issue
- 93 lt1
- LT1 shuts off at idle
- burning oil smell
- is it common for maxed out fuel trim to switch sides?
- third opti in the less than a year!
- Spark Plugs- Which are the best LT1 M6
- Something smells fishy...or I mean gassy. And cranking before starting.
- Vibration coming from underneath my console
- code 36 and 41
- 93 LT1 stalls, then starts back up immediately
- Block differences by year
- Engine RPMs slow to drop/hunt when clutch is in.
- 355 Build Questions?
- '93 T/A Fuel Problem
- Pure Choice or stock
- Solid or poly motor mounts?
- Cost to replace LT1 plugs and plug wires
- #3 and #4 lean and the rest rich
- IAC valve
- LT1 slow start
- Looking for parts for a 1996 lt1 camaro!!!
- Opti-Spark inproper Installation damage valvetrain?
- Budget Cam swap
- happy hooker
- 97 z28 horsepower
- Alright Gentlemen
- 96 Z28 rough idling and running
- LT4 Hot Cam vs Comp XR270
- 2014 Corvette will have an LT1???
- 94 Z28 LT1 - engine running retarded
- Car smokes only at idle what can I do to stop it?
- oil pickup
- 97Z Fans wont come on at all
- EGR/Fuel Trim Questions
- remove EGR
- Redlining when started up?
- 97 z28 30th anniversary
- 96 Camaro Z28 rough idle, car shakes at lower RPM's when in gear
- Runs great for bout 30 mins then starts running like its on 4 cylinders
- Car smokes while at idle
- '93 3.4 V6 to OBD-1 LT1 Harness questions
- Ltcc question
- Engine question on my 94 z
- service engine soon light/94 lt1
- How to remove the fuel presser regulator LT1?
- 94 Alternator vs 95
- 97 Z28 power loss
- What's next?
- pcm ground wire
- Cooling issue...
- Vacuum line from AIR/Smog pump
- major bogging durring heavy acceleration
- any trick on finding exhaust leaks
- Race Headers Longtube
- EGR Hose C/Vl(passenger side)
- Help W/Winter Upgrade
- Shorties with H/C?
- lt1 heads
- Need help with a belt squeak?
- Strange knock?
- High Idle
- Should I change my timing chain too?
- '93 Z28 A/C Clutch Removal
- Died while in neutral
- Glowing Converter/ Muffler Noise/ Power Loss
- Lowering Comp ratio?
- OptiSpark Sale
- Road trip Suggestions
- Bolt on advice for new LT1 purchase
- power steering pump
- Suddenly died, runs for a few secs on 1 cylinder...opti?
- strange noise..
- running on 7 cylinders... injector help
- What is the best fitting header?
- No spark at coil
- coil wiring
- acceptable compression numbers on a test
- 96 LT1 K-member. Are coupe and vert the same?
- Misfires and lagging when acceleration.. Idles ok
- Data log and tune
- Help... Car lagging at acceleration no vaccum leaks new intake elbow
- Need help with PO307 misfire cyl #7
- PN for vacuum reducer for EVAP solenoid?
- What do you think?
- failed inspection. codes 61/67
- Alternator relocation
- finally time to bring it somewhere
- Cam, Programmer, springs
- Question about a forged block for sale
- Oil pan removal?
- fuel pressure issues
- Purpose Of Metal Nipple On Throttle Body
- water pump drive gear
- name that sound
- Does this wire ground to the coil?
- Need help locating crank sensor pigtail on 96 LT1
- Best cam that will maintain stock low end torque
- ad misfire on low rpms
- SES light comes on when freeway cruising
- do i need a bigger radiator?
- overheating
- I need power steering reservoir reference photos 96 camaro
- Trans am fan promblem
- Windows are more important than a 383
- Stock Engine Swap Not Cranking
- lt1 miss and popping exhaust
- Coolant Crossover Pipe Hose
- exhaust popping???
- P0133 & P0153? Help!
- TPiS Engines?
- Matching Numbers? Do they do that on 4th gens?
- head gasket blown
- Oil loss- help diagnosing where
- Crispy Connectors
- 1995 z28 proformace help
- no ground at coil
- car running rough and 02 voltage low
- lt1 oil pressure help
- Oil filter relocation question
- Slp cold air induction package
- Intake Qestion for LT1
- Yanking my engine out!!
- water pump coupler O rings.
- Opti experts have a look
- Misfire question
- TB bypass
- LT1 rocker arms
- Low coolant light ?
- Will using 10w40 in my high milage LT1 be ok or no?
- dyno tuned my car
- cheap performance mods
- ltcc question
- starter replacement on 1996 lt1
- Rotella 15w40
- troubleshooting new motor
- LT1 difference
- Anyone identify these head bolts? pics inside
- Just buttoned up quite a few mods on my Formula.. HUGE DIFFERENCE!
- What rearend/gearing to go with?
- new camaro ticking problem
- 95 z28 starts and dies
- lt1 oil cooler delete
- Oil pump drive install
- test and tune
- break in oil - is it worth it?
- Opti... Spark...
- delteq
- Three broken valve springs!
- need help asap
- No start after fill up at the gas station...
- camaro/impala
- if your asking for help be respectful
- Oil pump screen
- oil dipstick
- FelPro Head Gasket Set Question
- Car will crank, but wont start.
- Urgent plz help!!!
- new opti problems
- EGR valve location ??
- Header bolts or studs?
- Throttle body bypass increase gas consumption?
- Flow control valve (restrictor) necessary?
- CC503?'s inside!!
- oil
- 95 LT1 surging, misfire
- finally thinking about a cam swap
- preload and not knowing lifter???
- 6.125 rods in a 355?
- 1996 camaro lt1 build questions
- valve locks and retainers
- P0133, where to start?
- vacuum question
- Fuel line replacement
- 2 probems.Oil Leak.Can't Find It. Antifreeze smell when heat is on.
