burning oil smell
Old Jan 24, 2013 | 10:36 PM
johnboyz28's Avatar
burning oil smell
if i sit at a light to long my car smells like burning oil inside car does not over heat stays at about 160 180 just fills cab with burning oil smell put it in first and take off it goes away 1997 z28
Posted from Camaroz28.com App for Android
Old Jan 24, 2013 | 10:46 PM
RamAir95TA's Avatar
Re: burning oil smell
Have you tried popping the hood? If you're burning oil smoke should be visible. Use a flashlight around dusk to help find the smoke. Obviously your efforts should be focused on the exhaust components (manifolds, y-pipe, etc.). If you come up empty handed you'll have to get beneath the car to check the rest of the exhaust.
Old Jan 25, 2013 | 04:19 PM
Scrub88's Avatar
I would check around your dip stick were it goes into the pan and its support bracket I had a similar issue . It would drip from the broken support bracket (2small holes) and from being loose in the pan dripping onto the exhaust
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jwade88
Jun 14, 2015 09:38 PM
surreybrad
Apr 22, 2015 06:40 AM
blac94Z
Jan 12, 2015 05:44 PM
