camaro/impala
Old Nov 8, 2012 | 05:30 PM
Shaun 95 camaro's Avatar
camaro/impala
Im currently looking for an lt1 for my camaro. Im looking on craigslist and I see alot of impala lt1s for sale. What is the difference between each motor. I know the camaro lt1 has more hp, but what is different? Does the camaro have better heads and do they have the same shortblock internals or not.
Old Nov 8, 2012 | 05:54 PM
parkers Z28's Avatar
Re: camaro/impala
Camaro has aluminum heads. and a different cam shaft ??? in my opinion I would stick with the camaro engine ..I'm sure there are some other stuff to. But if I was to say anymore I would be speculating
Old Nov 8, 2012 | 06:01 PM
Re: camaro/impala
The bottom end went out in my motor. So if I bought an lt1 out of a impala, used the short block and used the rest of my motor from the heads up, would that be a big difference hp wise. Has anyone ever done this?
Old Nov 8, 2012 | 06:30 PM
bw_hunter's Avatar
Re: camaro/impala
The cam is slightly different but not enough that you'd feel the power difference. The big difference between the two engines is the heads..the aluminum heads apparently cool better and allow more ignition advance. Swap 'me and you'll be fine...
Old Nov 15, 2012 | 05:03 PM
QICSAN's Avatar
Re: camaro/impala
The impala ss iron heads actually flow better but they just weight alot more.
Sort of an even trade off.
ChrisL
May 16, 2007 05:41 PM
ZYA_LTR
Nov 16, 2005 05:25 PM
