94 Alternator vs 95
Old Jan 6, 2013 | 01:57 PM
leebo's Avatar
94 Alternator vs 95
Can I use a 94 alternator on a 95 Z28? I already notice the supporting brackets are different. The 94 is off a auto car. The 95 is a 6 speed. Is the voltage the same?
thanks Lee
Old Jan 6, 2013 | 02:42 PM
RamAir95TA's Avatar
Re: 94 Alternator vs 95
The alternators are identical and interchangeable.
Old Jan 6, 2013 | 03:47 PM
leebo's Avatar
That's what I thought. I have a 94 I'm using as a parts car. I took the brackets off the 94 and placed them on the 95 motor and tried to use the 95 alternator. The brackets didn't line up. These are the support brackets on the back of the alternator. The hole in the back of the alternators is in a different location. So, I put the 94 alternator and and it lined up fine. Also, the power wire hooks up different. The 94 car doesn't run and I bought it that way. So, I don't know if the alternator even works.
Old Jan 6, 2013 | 10:32 PM
If you have an 93 to early 94 alternator (124 Amp), it will have a metal fan and the power cable will connect with a bolt. A late 94 and up alternator (140 Amp) will have a plastic fan and a stud for the power cable.
I am not aware of any mounting bracket difference, though (if they are both F-body alternators). The parts book shows all the brackets the same for 93-97.
Old Jan 7, 2013 | 05:59 AM
leebo's Avatar
Would the voltage difference cause me any problems?
I'm using the 124 amp on my 95 car.
thanks Lee
Old Jan 7, 2013 | 06:29 AM
thanks Lee
I doubt there would be any problems, unless you have some added equipment (ex. stereo system) that requires extra power.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
