remove EGR
Old Jan 13, 2013 | 05:21 PM
johnboyz28's Avatar
remove EGR
i read that a guy removed his egr from his z28. was wondering how you go about doing that. 97 z28 30th
Posted from Camaroz28.com App for Android
Old Jan 13, 2013 | 06:55 PM
RamAir95TA's Avatar
Re: remove EGR
Buy a block-off kit. Most vendors and site sponsors carry them. Then, remove the EGR tube from the exhaust manifold to intake manifold and block it off. Remove the EGR valve, solenoid, and vacuum line and plug the fitting on the intake manifold with a vacuum cap. Have the PCM reprogrammed to clear the EGR operation and you're done.
Old Jan 13, 2013 | 07:10 PM
johnboyz28's Avatar
what exactly does this do for my engine
Old Jan 13, 2013 | 07:16 PM
Kevin Blown 95 TA's Avatar
Re: remove EGR
Probably gets you slightly worse mileage in cruise conditions and possibly worse nox emissions. On the other hand, it cleans up the engine compartment and makes it easier to work on.
Old Jan 13, 2013 | 07:27 PM
Dan93z28's Avatar
Re: remove EGR
I deleted my EGR for weight savings and to clean up the engine bay. Havent heard of any effect to engine performance.
If the car needs to pass emissions you should probably keep it.
Old Jan 13, 2013 | 07:31 PM
johnboyz28's Avatar
im not worried about emissions. do i have to do any specific new tuning after i install the block off kit?
Old Jan 13, 2013 | 07:34 PM
johnboyz28's Avatar
im already tripping a code that my egr valve is bad.
Old Jan 13, 2013 | 07:55 PM
bw_hunter's Avatar
Re: remove EGR
There's your answer right there. If you disconnect the egr on an obd2 car you WILL trigger a code/check engine light. The only way around this is to tune it out.
By he way, egr doesn't hurt performance at all.....just fixing it may be cheaper.
Old Jan 13, 2013 | 08:16 PM
johnboyz28's Avatar
thanks guys new to the lt1 scene just want my z to run right
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
