Strange knock?
Old Dec 29, 2012 | 09:24 PM
mikemassi's Avatar
Strange knock?
I have a 94z a4 with built trans. My car randomly started making a weird metal knocking/chattering sound and when I had it on a lift sounds like its coming from the converter. Weird part is the noise is only present at idle in park,neutral,drive, or reverse. As soon as I give it any throttle the noise goes away. Any ideas?
Old Dec 30, 2012 | 09:06 AM
Guest47904's Avatar
Guest
Re: Strange knock?
Check the bolts that hold the converter to the flywheel and try moving it while your there in case the hub cracked.
Old Dec 30, 2012 | 10:38 AM
mikemassi's Avatar
Re: Strange knock?
i pulled off the dust shield and inspected everything the other day and everything looked perfect. all bolts where tight, flex plate wasent damaged. converter had no play. it sounds like nails are spining in the converter... is that possible and the fluid is clean and car runs perfect still?
Old Dec 30, 2012 | 12:13 PM
Guest47904's Avatar
Guest
Re: Strange knock?
Sounds like maybe you lost a vane or 2 inside. Would kind of make sense since at low speed you hear them and at higher speeds as centripetal force holds them to the case.
If that were the case, you could hear it better by rotating the engine over by hand.
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
