EGR valve location ??
Re: EGR valve location ??
There is no code that says the EGR valve is clogged. There are codes that tell you if the EGR vacuum solenoid electrical circuit is bad, and codes that tell you there is no measureable flow through the EGR system (measured by looking at the changes to the MAP sensor when the EGR valve is cycled). But the cause of no flow could be a broken vacuum line, a jammed EGR vacuum solenoid, a faulty EGR valve, or plugged passages. The sensitivity of the diagnostics also vary with the year of the engine.
stockssn2o
May 25, 2015 08:54 AM
