1994 z28 starting problem
Old Feb 10, 2013 | 07:51 PM
Readenour's Avatar
Unhappy 1994 z28 starting problem
So the other day I was driving my z28, and all of a sudden it died out of no where. So after having it towed back I began to look at it and couldn't find anything! So I tried starting it and it tried to crank over but It wouldn't! So I thought it was the ignition control module or the ignition coil so I took both of them out and had them tested! They tested fine! So after putting it all back together I tried it once more, just in case! But I for got to plug in the wire from the distributor into the ignition coil, the only way I noticed was the spark I saw coming from the wire. So once I plugged that in I tried to start it and it worked! But about 20 seconds in it died and hasnt started since and I removed the wire to see if it was still sparking and it was not! What could it be... Help
Old Feb 11, 2013 | 10:56 AM
Chet1185's Avatar
Check the ignition fuse under the hood.
Posted from Camaroz28.com App for Android
Old Feb 11, 2013 | 11:43 AM
timnfxr's Avatar
Re: 1994 z28 starting problem
Check the fuel pressure with key on, engine off to eliminate a fuel pump related problem.
Old Feb 11, 2013 | 03:22 PM
Readenour's Avatar
I ohm the ignition fuse, it was good, so was the fuel pressure
Old Mar 5, 2013 | 11:31 AM
squarehead's Avatar
Wow does this sound familiar. The same thing happened to me on Feb. 16th and I just got the car running last Saturday : Optispark!!!!
Let me know if you still have the trouble.
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
94z28jbw
Sep 8, 2002 03:22 PM
