Coolant going into the oil pan
Hello everyone, im having a problem with my rebuild... everything is tightened to specs and connected properly, but when it comes to filling up the radiator we noticed that as soon as we put coolant into it it all starts POURING out from the oil pan drain. Can anyone please help me out as to what it can be. Any help will be GREATLY appreciated
Posted from Camaroz28.com App for Android
Re: Coolant going into the oil pan
can the block actually crack just by sitting there, because before the rebuild it was in excellent working conditions.. only reason it was taken apart was because the thread on the header bolt holes was stripped, so I took them to get redone
Re: Re: Coolant going into the oil pan
Larry (Popo8) Co-owner
LTXtech.com
Originally Posted by popo8
u pulled and rebuilt ur motor over a stripped header bolt hole?!!
LTXtech.com
LTXtech.com
I have seen this once before on an lt1. A friend of mine had the exact same problem. Everyone thought it was the head gasket. As it turned out, the cylinder wall was split. We thought it was caused by either a previous rebuild with to much over bore or a casting flaw from brand new with too much core shift. When you had the heads off did you look at the tops of the pistons to see if they were marked .030 or .040 or the like? Possibly from a previous rebuild.
