Head Gaskets + Heads
Old Jan 25, 2013 | 07:11 PM
camar06702's Avatar
Well, the car has 130xxx miles and head gaskets finally decided to go. While I am already having the head gaskets replaces, along with re-machining the heads, cleaning out everything and replacing all gaskets and such. While I have everything out, is there anything that can be done (inexpensively) to the heads to give the car a boost in power? I am not too experienced with rebuilding engines and as you can see in the sig. the car in basically stock. Any suggestions are greatly appreciated!
Old Jan 25, 2013 | 09:51 PM
RamAir95TA's Avatar
Re: Head Gaskets + Heads
Not without spending some serious money, no. There isn't much you can do.
Although you COULD put on a thinner head gasket. That will give you a slight bump in compression and in turn maybe 2-3 HP.
Old Jan 26, 2013 | 01:53 AM
Locruid's Avatar
Perfect Time to do Long Tube Headers though.....
And they make a HUGE difference.
Just not sure what your budget is like........
Old Jan 26, 2013 | 03:26 AM
lt1-xjs's Avatar
Remove the casting marks in the bowls and ports, a good 3 angle (racing) valve job, upgraded springs and use the Impala head gasket. Top it off with some roller rockers.
Old Jan 26, 2013 | 07:15 AM
maybe2fast's Avatar
yup^, have the heads machined and 3 angled. and do some light clean up as stated and use the impala HG or the Mr. Gasket HG. Fresh spark plugs and Long tubes! enjoy
Old Jan 26, 2013 | 01:03 PM
camar06702's Avatar
Great! Thanks for the suggestions.. Budgets a little low so headers are going to be a future project. I figured since the engines apart, might as well get it machined professionally.
Old Jan 26, 2013 | 06:02 PM
Locruid's Avatar
Check Your Engine mounts too.
Wish I woulda remembered when I did my heads. They can be a serious pain to put in without Headers and not TOOOO bad with headers.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
